Find and change settings quickly
  • Updated
Find out how to use Quick Settings to get immediate access to commonly used features, such as Wi-Fi, Bluetooth, and Airplane mode.
ⓘ These steps require Android 13 or later. Find out How to check and update your software version.
Finding and using Quick Settings
You can open Quick Settings from any screen on your phone:
  1. On your Fairphone, swipe down from the top of your screen to see the first few settings.
  2. Swipe down again to open all Quick Settings.
  3. You can:
    • Tap a setting to turn it on or off.
    • Touch and hold a setting to see more options.
Rearrange your Quick Settings
To move, add or remove a setting:
  1. On your Fairphone, swipe down twice from the top of your screen to open all Quick Settings.
  2. At the bottom left, tap Edit (pencil icon).
  3. To adjust your settings:
    • Move: Drag the setting to where you want it.
    • Add: Drag a setting from the bottom section to the top.
    • Remove: Tap the Remove (–) icon on the setting, or drag it down to the bottom section.
