How to charge your Fairphone battery
To actively reduce e-waste, Fairphone smartphones do not include a charger or cable in the box. Check these requirements to make sure your existing accessories safely and efficiently charge your phone.
Your Fairphone comes with a removable, lithium-ion battery. To charge your phone safely:
- Connect one end of your charging cable to a compatible power adapter.
- Connect the USB-C end of the cable (or Micro-USB cable for the Fairphone 2) to the charging port at the bottom of the Fairphone.
- Connect your power adapter directly to a working wall outlet.
Power requirements by Fairphone model
| Fairphone model | Cable requirements | Charger requirements |
| Fairphone (Gen. 6/Gen. 6+) | High-quality USB-C to USB-C cable (minimum 60W / 20V, 3A) | USB Power Delivery (USB PD) charger supporting PPS at a minimum of 30W (9V, 3A), or Quick Charge 4.0+ |
| Fairphone 5 | High-quality USB-C to USB-C cable (minimum 60W / 20V, 3A) | USB Power Delivery (USB PD) charger supporting PPS at a minimum of 30W (9V, 3A), or Quick Charge 4.0+ |
| Fairphone 4 | High-quality USB-C to USB-C cable (minimum 60W / 20V, 3A) | USB Power Delivery (USB PD) charger supporting PPS at a minimum of 30W (9V, 3A), or Quick Charge 4.0+ |
| Fairphone 3 / 3(+) | High-quality USB-C to USB-C cable (minimum 60W / 20V, 3A) | Charger supporting Quick Charge 3.0 or above |
| Fairphone 2 | High-quality Micro-USB (Micro-B) cable | 5V charger with a minimum current of 1A (1000mA) |
Frequently asked questions
Why is there no cable or charger included in the box?
Fairphone was one of the first smartphone manufacturers to actively reduce e-waste by omitting cables and chargers from product packaging. There is a high chance you already own compatible accessories at home. To learn more about this decision, watch episode 1 of Ask the experts.
Can I charge my Fairphone wirelessly?
No, Fairphone smartphones do not support wireless charging because wired charging is significantly more efficient. We may consider wireless charging in the future as technology improves.
How can I tell if my Fairphone is charging?
When you plug in your phone, the display lights up and shows the current battery percentage. You can also turn on charging feedback by going to Settings > Sound & vibration and toggling Charging sounds and vibration.
Where can I buy compatible charging accessories?
If your existing accessories are incompatible, you can buy official cables and power adapters designed for your phone in the Fairphone online shop.
How long will it take to charge the battery of The Fairphone (Gen. 6/Gen. 6+)?
When using a Fairphone cable and charger, or compatible third-party alternatives, you can expect to reach:
- 50% in about 22 minutes
- 80% in around 37 minutes
- 100% in about 85 minutes
Can I use a wireless charger on The Fairphone (Gen. 6/Gen. 6+)?
No, The Fairphone (Gen. 6/Gen. 6+) does not support wireless charging, similar to the Fairphone 5 and Fairphone 4.
When designing the Fairphone, we initially considered wireless charging. However, every design choice involves trade-offs, and we wanted to prioritize what matters most to our users, such as better battery life and a sleek design.
Can I purchase a Fairphone wall charger?
Yes, EU wall chargers are available for purchase directly from the Fairphone online shop.
Please note that UK wall chargers have been discontinued. If you are in the UK, you can safely use any high-quality, third-party USB Power Delivery charger that supports a minimum of 30W.
Still need help?
