How to replace parts on your Fairbuds XL
The Fairbuds XL modular design makes replacing individual parts quick and simple so your headphones last longer.
There are nine interchangeable spare parts available on Fairphone's online shop:
- Battery
- Headband Base
- Headband Cover
- Headband
- Ear Cushion (Textile or PU Leather)
- Speaker Covers
- Speaker to Speaker Cable
- Left Speaker
- Right Speaker
Select your specific repair guide below to learn how to replace component parts on your device.
Rather leave it to us? Contact Customer Support to schedule a repair appointment.
Select your repair guide
- How to replace the battery and speaker cover on Fairbuds XL: Replace worn batteries or access the inner earcup cavity.
- How to replace ear cushions on Fairbuds XL: Swap worn fabric earpads using our tool-free twist-and-click system.
- How to replace a speaker unit on Fairbuds XL: Restore sound quality or replace a faulty left or right speaker unit.
- How to replace the headband base on Fairbuds XL: Repair broken mounting clips between the headband and earcups.
- How to replace the headband, cover, and cable (Fairbuds XL 2025): Replace internal audio cables, headband frames, or slide-on covers on 2025 models.
- How to replace the headband, cover, and cable (Fairbuds XL 2023): Replace internal audio cables, headband frames, or fold-open covers on 2023 models.
Still need help?
