How to use your new Fairphone
Welcome to Fairphone! This guide helps you set up your new smartphone, personalize your settings, and get the most out of everyday features.
Watch a video introduction
Select your model below to watch a quick video tour and learn your way around your phone:
The Fairphone (Gen. 6/Gen. 6+)Fairphone 5Fairphone 4Fairphone 3(+)
Getting started
- Check your parcel: Verify that your delivery box is undamaged before opening your smartphone package.
- Charge the battery: Connect your smartphone to a compatible charger. If your phone does not turn on immediately, charge the battery for at least two hours before completing the setup.
- Follow the setup wizard: Press and hold the power button to turn on your smartphone. The setup wizard will guide you through connecting to WiFi, installing your SIM card, activating your eSIM, and adding your Google account.
- Customize your settings: Adjust your preferences during the wizard or skip optional steps to configure them later in your phone settings.
Set up essential features
Explore these step-by-step guides to customize your options and start using your phone:
Getting started
- Turn your phone on and off
- Download and manage apps
- Switch to your new Fairphone
- How to charge your Fairphone battery
- How to connect to a Wi-Fi network
Personalization
- Customize your Home screen
- Personalize your wallpaper and sound
- How to set up Fairphone Moments (Fairphone Gen.6)
- Find and change settings quicklyFind and change settings quickly
Communication
- Make calls, send messages, and set up email
- Change your language settings
- How to connect to a Bluetooth device
Everyday tips and shortcuts
Still need help?
If you still require assistance, reach out to our customer support team. You can also open a support request directly through the My Fairphone app pre-installed on your device.
