How to delete an eSIM from your Fairphone
  • Region:United States
  • Updated
You can delete an eSIM profile from your Fairphone if you plan to switch mobile network operators or prepare your phone for a new owner.
Applies to
  • Fairphone 4 and later models
How to remove an eSIM profile
Deleting an eSIM erases the active profile from your device. If you plan to reinstall the same profile later, ensure you have a valid QR code from your network operator before removing it.
  1. Go to Settings > Network & internet > SIMs.
  2. Tap the name of the SIM profile you want to delete.
  3. Tap Erase SIM.
