Using your Fairphone on cellular networks in the United States
  • Updated
Learn which cellular networks support your Fairphone in the United States and how to stay connected.
See carrier compatibility
Supported phone models
  • The Fairphone (Gen. 6+) purchased in the United States
Connecting to US cellular networks
The Fairphone (Gen. 6+) sold in the United States is fully unlocked and supported on Boost Mobile, T-Mobile, and AT&T cellular networks.
To ensure a seamless connection, customers may need to contact their carrier to have their device activated on the network.
Fairphone models purchased outside of the United States require network compatibility verification using your phone IMEI when connecting to US networks. To use a Fairphone purchased in Europe within the United States, contact your network operator directly to verify phone IMEI compatibility.
Technical network specifications
The Fairphone (Gen. 6/Gen. 6+)
  • Configuration Dual-SIM, Dual-Standby (DSDS)
  • eSIM x 1 - 5G enabled*
  • SIM x 1 Nano-SIM - 5G enabled*
  2G 3G HSPA+ 4G LTE 5G
Max Downlink Speed 296 Kbit/s 42 Mbit/s 1.2 Gbit/s 2.9 Gbit/s
Max Uplink Speed 236.8 Kbit/s 5.76Mbps 200 Mbit/s 200 Mbit/s
Supported frequencies / bands 850, 900, 1800, 1900 MHz HSDPA Cat. 24
HSUPA Cat. 6, Bands: 1/2/5/8
4 x 4 MIMO support
VoLTE + VoWiFi
LTE bands:
B1, 2, 3, 4, 5, 7, 8, 12, 17, 20, 25, 26, 28, 32, 38, 40, 41, 42, 48, 66, 71
Sub NSA bands:
n1, 2, 3, 5, 7, 8, 20, 28, 38, 40, 41, 66, 71, 77, 78
* Only one SIM card at a time will be active on the 5G network.
Fairphone 5
  • SIM x 1 Nano-SIM (4FF) - 5G enabled*
  2G 3G HSPA+ 4G LTE 5G (both NSA & SA)
Max Downlink Speed 296 Kbit/s 42 Mbit/s 1.2 Gbit/s 2.3 Gbit/s
Max Uplink Speed 236.8 Kbit/s 6.76 Mbit/s 200 Mbit/s 200 Mbit/s
Supported frequencies / bands 850, 900, 1800, 1900 MHz 850, 900, 1900, 2100, MHz (1/2/5/8) 1, 2, 3, 4, 5, 7, 8, 12, 20, 28, 32, 38, 40, 41, 42, 48, 66, 71 1, 2, 3, 5, 7, 8, 20, 28, 38, 41, 48, 66, 71, 77, 78
Fairphone 4
  • Network Technology 2G / 3G HSPA+ / 4G LTE / 5G
  • 5G Max Downlink Speed - 2.3 Gbps
  • 5G Max Uplink Speed - 200 Mbps
  • 5G Supported Bands (Sub 6 NSA bands): n1, n3, n5, n7, n8, n20, n28, n38, n41, n71, n77, n78
  • 4G Max Downlink Speed - 1.2 Gbps
  • 4G Max Uplink Speed - 150 Mbps
  • 4G LTE Supported Bands: 1, 2, 3, 4, 5, 7, 8, 12, 18, 19, 20, 28, 32, 38, 40, 41, 71
  • 3G HSPA+ Supported Bands: 1, 2, 4, 5, 8
  • 2G Supported Bands (GSM, GPRS, EDGE): 850, 900, 1800, 1900 MHz
Fairphone 3(+)
  • SIM Sockets 2 x Nano-SIM (4FF)
  • Network Technology 2G / 3G / 4G LTE - Advanced
  • GSM/GPRS/EDGE Quad-band: 850, 900, 1800, 1900 MHz
  • UMTS: Band 1 (2100 MHz); Band 2 (900 MHz); Band 5 (850MHz); Band 8 (900 MHz)
  • 3G Max Downlink Speed - 42 Mbps
  • 3G Max Uplink - 11 Mbps
  • 4G / LTE Advanced Band 1 / 2 / 3 / 4 / 5 / 7 / 13 / 20 / 26
  • 4G Max Downlink Speed - 300 Mbps
  • 4G Max Uplink Speed - 75 Mbps
Frequently asked questions
How do I have my device activated on my cellular network?
If you're experiencing issues with your Fairphone connecting to your cellular network, contact your carrier's customer service and request that your device is activated according to their Bring Your Own Device procedure. You'll use your IMEI number or your EID to identify your device.
Related articles
Still need help?
