Global network coverage
If you are traveling or living outside Europe and the United States, your Fairphone can connect to local mobile networks. This guide explains international roaming settings, regional network compatibility, and device setup steps.
Supported phone models
- The Fairphone (Gen. 6+)
- The Fairphone (Gen. 6)
- The Fairphone 5
- The Fairphone 4
- The Fairphone 3, and The Fairphone 3+
How to turn on roaming for international travel
- Contact your intended mobile network operator to verify roaming capabilities and confirm their broadcast frequency bands match your phone specifications.
- Open Settings on your smartphone.
- Tap Network & internet > SIMs.
- Tap your active SIM card, then turn on Roaming.
- Restart your phone after arriving at your destination to register on the local cellular network.
Understanding international roaming and global network compatibility
Because cellular frequency bands and carrier standards vary globally, full network compatibility outside Europe and the United States cannot be guaranteed. Contact your local intended network operator to confirm if the operator supports your phone.
Keep in mind:
- 5G and 4G LTE connectivity: Your phone connects to international 4G networks when mobile data and roaming are enabled in settings. If your Fairphone supports 5G, the phone can also connect to most 5G networks.
- VoLTE and VoWiFi features: If a local provider relies on Voice over LTE (VoLTE) or Voice over WiFi (VoWiFi) and has not provisioned your specific Fairphone model, you may experience dropped calls or connection delays.
- Regional variations: Only The Fairphone (Gen. 6+) units purchased specifically in the United States are officially supported on US networks due to local network limitations. Check with your local network operator to confirm if the operator supports your model.
Technical network specifications
The Fairphone (Gen. 6/Gen. 6+)
- Configuration Dual-SIM, Dual-Standby (DSDS)
- eSIM x 1 - 5G enabled*
- SIM x 1 Nano-SIM - 5G enabled*
| 2G | 3G HSPA+ | 4G LTE | 5G | |
| Max Downlink Speed | 296 Kbit/s | 42 Mbit/s | 1.2 Gbit/s | 2.9 Gbit/s |
| Max Uplink Speed | 236.8 Kbit/s | 5.76Mbps | 200 Mbit/s | 200 Mbit/s |
| Supported frequencies / bands | 850, 900, 1800, 1900 MHz |
HSDPA Cat. 24 HSUPA Cat. 6, Bands: 1/2/5/8 |
4 x 4 MIMO support B1, 2, 3, 4, 5, 7, 8, 12, 17, 20, 25, 26, 28, 32, 38, 40, 41, 42, 48, 66, 71 |
Sub NSA bands: n1, 2, 3, 5, 7, 8, 20, 28, 38, 40, 41, 66, 71, 77, 78 |
* Only one SIM card at a time will be active on the 5G network.
Fairphone 5
- SIM x 1 Nano-SIM (4FF) - 5G enabled*
| 2G | 3G HSPA+ | 4G LTE | 5G (both NSA & SA) | |
| Max Downlink Speed | 296 Kbit/s | 42 Mbit/s | 1.2 Gbit/s | 2.3 Gbit/s |
| Max Uplink Speed | 236.8 Kbit/s | 6.76 Mbit/s | 200 Mbit/s | 200 Mbit/s |
| Supported frequencies / bands | 850, 900, 1800, 1900 MHz | 850, 900, 1900, 2100, MHz (1/2/5/8) | 1, 2, 3, 4, 5, 7, 8, 12, 20, 28, 32, 38, 40, 41, 42, 48, 66, 71 | 1, 2, 3, 5, 7, 8, 20, 28, 38, 41, 48, 66, 71, 77, 78 |
Fairphone 4
- Network Technology 2G / 3G HSPA+ / 4G LTE / 5G
- 5G Max Downlink Speed - 2.3 Gbps
- 5G Max Uplink Speed - 200 Mbps
- 5G Supported Bands (Sub 6 NSA bands): n1, n3, n5, n7, n8, n20, n28, n38, n41, n71, n77, n78
- 4G Max Downlink Speed - 1.2 Gbps
- 4G Max Uplink Speed - 150 Mbps
- 4G LTE Supported Bands: 1, 2, 3, 4, 5, 7, 8, 12, 18, 19, 20, 28, 32, 38, 40, 41, 71
- 3G HSPA+ Supported Bands: 1, 2, 4, 5, 8
- 2G Supported Bands (GSM, GPRS, EDGE): 850, 900, 1800, 1900 MHz
Fairphone 3(+)
- SIM Sockets 2 x Nano-SIM (4FF)
- Network Technology 2G / 3G / 4G LTE - Advanced
- GSM/GPRS/EDGE Quad-band: 850, 900, 1800, 1900 MHz
- UMTS: Band 1 (2100 MHz); Band 2 (900 MHz); Band 5 (850MHz); Band 8 (900 MHz)
- 3G Max Downlink Speed - 42 Mbps
- 3G Max Uplink - 11 Mbps
- 4G / LTE Advanced Band 1 / 2 / 3 / 4 / 5 / 7 / 13 / 20 / 26
- 4G Max Downlink Speed - 300 Mbps
- 4G Max Uplink Speed - 75 Mbps
Related articles
- Using your Fairphone on mobile networks in Europe
- Using your Fairphone on cellular networks in the United States
Still need help?
If you still require assistance, reach out to our customer support team. You can also open a support request directly through the My Fairphone app pre-installed on your device.
