Google Gemini AI assistant on Android
We are excited you are exploring Gemini on your Fairphone! As Gemini is now the default AI assistant, getting started is straightforward. Here is what you need to know for your first interaction.
At Fairphone, we prioritize your control. While Gemini is a Google service, you always have the choice to switch off Gemini on your device. You can manage your data usage and privacy settings directly within the Gemini app and your Google profile.
ⓘ These steps require Android 13 or later. If you are not sure which version your Fairphone is running, see How to check and update your software version.
How to activate Gemini
To use Gemini, your Fairphone needs an active internet connection and you must be signed into your Google account.
Here are a few easy ways to start using it:
Press and hold the Power button
On newer Fairphone and Android versions, pressing and holding the Power button is set to trigger your digital assistant by default: Change what happens when you press and hold the power button.
Talk to Gemini hands-free
If Voice Match is enabled, you can just say "Hey Google" to access Gemini any time your screen is on. To turn on Voice Match:
- On your Fairphone, open the Gemini app and tap your profile picture in the top right.
- Then, go to Settings → Talk to Gemini hands-free.
- Tap Hey Google and follow the setup process.
Use the Gemini app
On your phone, swipe up from the Home screen to see All Apps, then look for Gemini and tap to open it.
How to use the Gemini app
Once you've opened the Gemini app, you can interact with it in two ways:
- Speak your request: Tap the microphone icon and speak your question or command clearly.
- Type your request: Type your question into the text field and then tap "Send."
For the best experience, always keep your Fairphone and the Gemini app updated to the latest version.
What you can do with Gemini
To learn how to activate and interact with the AI assistant on your Fairphone or via audio accessories, go and read this helpful information on Gemini from Android support:
- How to get started with the Gemini mobile app?
- What you can do with your Gemini mobile app?
- How can your Gemini mobile app help when your phone is locked?
- What is the Gemini mobile app availability per country, age or language?
- How to speak with Gemini mobile app?
- How to use Gemini on my headphones?
- How to use screen actions to chat with Gemini?
- How to add or customize my Gemini widget?
How to disable Gemini
If you wish to disable Gemini, you can either revert to Google Assistant or remove the digital assistant entirely.
- Option 1: Switch to Google Assistant:
- Tap Switch to Google Assistant → Google Assistant → Switch.
- Option 2: Set your default digital assistant app to "None":
- On your Fairphone, go to Settings → Apps → Default apps → Digital assistant app.
- Tap Default digital assistant app → None.
