Set up hotspot and tethering
  • Updated
You can use hotspot and tethering to share your Fairphone's mobile data connection with other devices via Wi-Fi, Bluetooth and more. This allows other devices to access the internet using your mobile data.
These steps require Android 13 or later. If you are not sure which version your Fairphone is running, see How to check and update your software version.
How do I set up a Wi-Fi hotspot?
To set up a Wi-Fi hotspot:
Note: Some network operators limit or charge additional fees to share your mobile data connection. Contact your network operator for details.
  1. On your Fairphone, go to Settings → Network & internet → Hotspot & tethering.
  2. Tap Wi-Fi hotspot and then tap Use Wi-Fi hotspot to toggle on or off.
Tip: You can also change your hotspot's name and password, or tap Security → None if you don't want to require a password.
How do I set up Bluetooth tethering?
To set up Bluetooth tethering:
  1. Using Bluetooth, connect your Fairphone with the other device.
  2. On your Fairphone, go to Settings → Network & internet → Hotspot & tethering.
  3. Tap Bluetooth tethering to toggle on or off.
Tip: Not all devices can access your Fairphone's mobile data via Bluetooth tethering. Check the device's support resources or contact the manufacturer for details.
How do I set up USB tethering?
To set up USB tethering:
  1. Using a cable, connect your Fairphone with the other device.
  3. Tap USB tethering to toggle on or off.
Tip: Use a cable that fits your Fairphone's USB-C port and the port on the other device.
Need help?
If hotspot and tethering isn't working, you can often fix it in just a few simple steps. Find out how: Troubleshoot a Hotspot Connection.
