How to turn your Fairphone on and off
  • Updated
Knowing how to power your phone on and off helps you manage daily use and quickly restart your phone when needed. You can also customize what happens when you press and hold the power button to match your preferences.
ⓘ These steps require Android 13 or later. Find out How to check and update your software version.
How to turn on your Fairphone
  1. Press and hold the Power button until the screen lights up.
How to turn off your Fairphone
  1. Press the Power button to wake the screen.
  2. Press the Power button and Volume up button at the same time.
  3. Tap Power off on the screen.
If enabled in your settings, you can also press and hold the Power button by itself to bring up the power menu.
Change your power button shortcuts
Pressing and holding the Power button on newer Android versions opens your digital assistant by default. You can change this setting to show the power menu instead.
  1. Go to Settings > System > Gestures.
  2. Tap Press & hold power button.
  3. Select your preferred option:
    • Power menu
    • Digital assistant
Still need help?
If you still require assistance, reach out to our customer support team. You can also open a support request directly through the My Fairphone app pre-installed on your device.
