How to connect to a Wi-Fi network
  • Updated
Connecting your Fairphone to Wi-Fi lets you access the internet to download apps, stream content, and keep your phone updated. Follow these steps to manage your Wi-Fi settings, join networks, and remove saved connections.
ⓘ These steps require Android 13 or later. Find out How to check and update your software version.
How to turn Wi-Fi on or off
You can manage your Wi-Fi connection using either the Settings app or your Quick Settings menu.
Using the Settings app:
  1. Go to Settings > Network & internet > Internet.
  2. Tap Wi-Fi to turn it on or off.
Using Quick Settings:
  1. Swipe down from the top of your screen to open the Quick Settings panel.
  2. Tap Internet, then tap Wi-Fi to turn it on or off.
  3. Tap and hold Internet in your Quick Settings panel to open your full network options.
  2. If Wi-Fi is turned off, tap the switch to turn it on. Available networks will appear in a list.
  3. Tap the name of the network you want to join.
  4. Enter the password if prompted, then tap Connect.
  5. Once your phone connects, you will see Connected displayed under the network name.
Manage automatic connections
Your phone automatically connects to saved networks whenever you are within range. To turn automatic connection on or off for a specific network:
  2. Tap the name of the saved network.
  3. Tap Auto-connect to turn the setting on or off.
How to remove a saved Wi-Fi network
If you want your phone to stop connecting to a specific network automatically:
  2. Tap the name of the network you want to remove.
  3. Tap Forget.
Need help connecting?
If your connection is unstable or fails to connect, find out how to troubleshoot a Wi-Fi connection.
Wi-Fi allows your Fairphone to connect to wireless networks. When connected to a Wi-Fi network, you can access the internet to download apps, stream music or video, and more.
Still need help?
If you still require assistance, reach out to our customer support team. You can also open a support request directly through the My Fairphone app pre-installed on your device.
