Scanning a QR code with your Fairphone
  • Updated
QR codes allow you to quickly access websites, connect to Wi-Fi, or find information. Depending on your Fairphone version, you can scan QR codes directly through Quick Settings or via the camera app.
These steps require Android 13 or later. If you are not sure which version your Fairphone is running, see How to check and update your software version.
Scan a QR code using Quick Settings
  1. On your Fairphone, swipe down twice from the top of your screen to open all Quick Settings.
  2. Tap QR code scanner.
Tip: If you don't see QR code scanner in your Quick Settings, find out how to add it: Find and change settings quickly.
Scan a QR code using the Camera app
If you have a Fairphone 4 or later, QR scanning is also built directly into the Camera app.
Fairphone (Gen. 6)
  1. On your Fairphone, open the Camera app.
  2. Point your camera at the QR code.
Fairphone 4 and 5
  2. Tap the Google Lens icon between the preview and capture button.
  3. Point your camera at the QR code.
Scan a QR code using the Google widget
If you have the Google widget on your Home screen, you can scan QR codes using Google Lens.
  1. On your Home screen, tap the Google Lens (camera) icon.
Tip: If you don't see the Google widget on your Home screen, find out how to add it: How to customize your Home screen.
