How to connect to a computer (with a cable)
  • Updated
You can use a cable to connect your Fairphone to a computer. When connected, you can transfer files, share internet access, and more.
These steps require Android 13 or later. If you are not sure which version your Fairphone is running, see How to check and update your software version.
Before you start
  • Use a cable that fits your Fairphone's USB-C port and the port on your computer.
  • Use a cable that can transfer data (some cables can only be used for charging).
  • Connect to a computer with at least Windows 10, Ubuntu 18.x or macOS 10.7.
How to connect to a Windows or Linux (Ubuntu) computer
To connect your Fairphone to a Windows or Linux (Ubuntu) computer, follow these steps:
  1. Unlock your Fairphone.
  2. Connect your Fairphone to your computer using a USB cable.
  3. On your Fairphone, swipe down from the top of the screen.
  4. Tap the Charging this device via USB notification.
  5. When you're ready to disconnect, unplug the USB cable.
    • If you're connected to a Windows computer, eject your Fairphone before unplugging the cable to safely disconnect.
Important: Windows may not recognize your Fairphone if the necessary drivers are missing. Try installing a universal driver, such as Universal ADB Driver.
How to connect to a macOS computer
To connect your Fairphone to a macOS computer, follow these steps:
Important: macOS has limited built-in support for Android devices. To transfer files between your Fairphone and a macOS computer, you'll need to install a third-party file transfer app on your macOS computer, such as OpenMTP.
Trouble connecting to a computer?
If you can't connect to a computer, you can often fix it in just a few simple steps. Find out how: Troubleshoot a Connection with a Computer.
