The Fairphone (Gen. 6/Gen. 6+): Frequently Asked Questions
Find support guides, specifications, and troubleshooting steps for the Fairphone (Gen. 6). Select a topic below to view dedicated articles, or refer to The Fairphone (Gen. 6/Gen.6+) User Manual.
General
What are the technical specifications of The Fairphone (Gen. 6)?
What are the safe operating temperatures for The Fairphone (Gen. 6/Gen. 6+)
Why does The Fairphone (Gen. 6) not have an audio jack?
Battery and Charging
How long will it take to charge the battery of The Fairphone (Gen. 6)?
Can I use a wireless charger on The Fairphone (Gen. 6)?
Connectivity
Can I install an eSIM on The Fairphone (Gen. 6)?
What Bluetooth version does The Fairphone (Gen. 6) support?
What USB version does The Fairphone (Gen. 6) use?
Software
What Android version does The Fairphone (Gen. 6) come with?
How long will The Fairphone (Gen. 6) receive software updates?
Is the Fairphone (Gen. 6) compatible with Android Auto?
Camera
How has the camera quality improved on The Fairphone (Gen. 6)?
Can I record 4K@60FPS video on The Fairphone (Gen. 6)?
Warranty
What is the warranty for The Fairphone (Gen. 6)?
Fairphone Moments
How can I customize Fairphone Moments?
Can I change what the Fairphone Moments switch does?
Sustainability
Is the Fairphone 6 TCO certified?
