How to fix choppy or disconnected Bluetooth audio on Fairbuds, Fairbuds 2, and Fairbuds XL
If your Fairbuds experience choppy audio or unexpected disconnects, adjusting your audio codec or environment usually restores a smooth, uninterrupted connection.
Applies to
- Fairbuds
- Fairbuds 2
- Fairbuds XL
What causes audio interruptions
Your Fairbuds rely on standard Bluetooth radio frequencies (RF) to stream sound from your paired phone. Audio stutters or drops typically happen when:
- High-resolution audio formats are enabled: Formats like LDAC or Hi-Res Audio transfer significantly more data per second, making the connection more sensitive to interference.
- Network saturation: Operating your Fairbuds in places with many active wireless signals (like crowded transit hubs or busy office spaces) can cause signal congestion.
- Physical barriers: Walls, heavy clothing, or keeping your phone in a deep pocket or bag can block the signal between your phone and your Fairbuds.
How to restore a smooth audio connection
Follow these steps to improve your connection stability and eliminate audio drops:
- Turn off LDAC, LE or Hi-Res Audio: Open the Bluetooth settings on your phone, select your Fairbuds, and disable LDAC, LE audio mode, or Hi-Res Audio. Switching to standard Bluetooth codecs like AAC or SBC stabilizes playback, especially while walking or in public spaces.
- Reduce physical obstacles: Place your phone closer to your Fairbuds and keep it on the same side of your body to maintain a direct line of sight.
- Move away from wireless interference: If you are near dense crowds or heavy Wi-Fi routers, step into a less crowded area to reduce signal congestion.
Still need help?
