How to replace parts on your Fairbuds 2
Whether you need to refresh a battery, adjust your fit, or replace a lost earbud, select any guide below for step-by-step instructions for replacing spare parts on your Fairbuds 2.
- How to replace the outer shell and core on your Fairbuds 2 charging case: Learn how to safely dismantle your charging case using a T5 Torx screwdriver to swap out a damaged outer shell or case core.
- How to change the charging case battery on your Fairbuds 2: Follow step-by-step instructions to remove the case core and replace the internal case battery to keep your Fairbuds 2 powered.
- How to replace the silicone rings and eartips on your Fairbuds 2: Find instructions for swapping out your silicone accent rings, as well as changing your eartips between the three included sizes for optimal comfort and seal.
- How to replace the Fairbuds 2 earbud batteries: Learn how to open the hidden battery compartment beneath the silicone ring to swap in fresh coin cell batteries for your earbuds.
- How to pair a replacement Fairbud 2: Lost an earbud? Perform a 10-second factory reset to pair a new replacement earbud with your existing set and reconnect to your devices.
Frequently asked questions
What makes the Fairbuds 2 repairable?
Seven user-replaceable components, including the battery in both the earbuds and the charging case, assembled with zero glue and no special tools. This is the same modular approach pioneered on the original Fairbuds, refined further.
What tools do I need to replace a battery myself?
You can replace the Fairbuds 2 earbud batteries with no tools required. To replace the charging case battery, you’ll need a Torx T5 screwdriver.
What happens if I lose one earbud? Can I buy a single replacement?
What spare parts are available for the Fairbuds 2?
Seven replaceable parts: the earbud battery, the charging case battery, the left and right earbuds (individually replaceable), S/M/L eartips, the charging case core (button, status LED, USB-C), and the charging case outer shell.
What does the LONGTIME® certification mean?
LONGTIME® is an independent European certification for products designed to last. It evaluates products against three pillars, based on specific standards: robust design, repairability, and service & warranties, and requires passing an independent audit against a defined set of criteria.
Are Fairbuds and Fairbuds 2 parts interchangeable?
The earbud battery and the case battery are interchangeable with the Fairbuds.
Still need help?
