Unlock your Fairphone if you forgot your PIN
  • Updated
If you cannot unlock your Fairphone because of a forgotten PIN, this guide helps you identify which PIN is locked and walks you through how to regain access to your phone.
Identify which PIN is locked
Your phone uses two separate PIN codes, which can easily be confused:
  • SIM PIN: Protects your SIM card and mobile network connection. If you forget your SIM PIN, you must request a PUK (Personal Unblocking Key) code directly from your network operator.
  • Screen lock PIN: Protects your personal data and unlocks your device display. If you forget this code, follow the troubleshooting steps below.
Remove your SIM card to test your screen PIN
Before resetting your phone, verify whether the prompt is asking for your SIM PIN or your screen PIN:
  1. Turn off your phone.
  2. Remove your SIM card(s).
  3. Turn your phone back on.
  4. Enter your screen unlock PIN.
If your phone unlocks, your screen PIN is correct and you only need a PUK code from your operator for the SIM card. If your phone remains locked, proceed to the reset steps below.
Perform a factory reset
  1. Perform a factory reset.
  2. Follow the setup prompts on the screen until the phone asks for your previous security code.
  3. Tap Verify your Google account instead and log in with your Google credentials.
A factory reset permanently erases all personal data, apps, settings, and media stored on your phone. Create a backup of your important files before proceeding.
If you cannot remember your Google username or password, contact Google directly for account recovery help.
Request a reset from our repair center
If you cannot unlock the phone or complete the reset, our repair center can reset the phone for you. This repair center reset will not void your remaining manufacturing warranty.
This service falls under ‘Assessment and labor costs for repairs without spare parts’. Shipping costs are separate and vary by country. For specific rates, review our repair price list.
Still need help?
